Отправлено: 18.11.08 12:10. Заголовок: # GI 890 HD problem
I have a problem with GI890.I use it with motor SG2100 (USALS),Problem is with freqency 12565 H 27500 3/4 on ASTRA 3A-23,5(slovak program TA3) this freqency normaly working,but when I turn dish to Thor or Amos and I back to astra 3 this freqency have not a signal.I must go to menu,tuning, and next signal start working.Do somebody try it?.I tried use all type firmware (original and with emu).Thank you for help.
Пост N: 146
Отправлено: 27.11.08 23:40. Заголовок: Ещё бы местность и р..
Ещё бы местность и размер тарелки... а то создаётся впечатление, что дело-то не в ресивере, а в люфте мотора. :) Даже добавлять в вашем почтовом районе и размере параствола... И это - Even to add in your post area and the size a parabola... And it - the created impression, that business not in the receiver, and in luft on motor.:)
Пост N: 62
Info: GI-S890 CRCI HD Excellence, 0,9 - 0.8_4.8_9_13_23.5_28.2_36
Отправлено: 12.05.09 16:02. Заголовок: It is a problem of a..
With delay....
It is a problem of all Golden Interstar 890, fur-trees at you two and more LNB! Very weak software! The receiver badly works with Diseq. All we wait for the decision of this problem programmers Golden Interstar. Now it is possible to solve this problem having replaced the software from analogue Octagon 918.
Отправлено: 13.05.09 20:14. Заголовок: ales_kopf and thus..
ales_kopf and thus here problem of diseq? a man did not write at etom not words.... but first, that occurred to me - reprogramm to Octagon918 and check
извиняюсь за некорректный перевод - пользовался переводчиком
Пост N: 118
Отправлено: 16.07.09 14:34. Заголовок: We improve quality of a picture on Octagon 918
I think, that Octagon guys leave in other direction. The picture on GIS 918 is much worse, than on Gis 890-th. As with the friend have taken GIS 890 simultaneously, one of these days was on what will compare. The friend has brought the device to me for his(its) alteration in Octagon. And here all happened … At GIS the picture on the same channel through HDMI is more white light and contrast. On Octagon at identical quality and capacity of a signal (one aerial), pixels are visible! From here morals: - it Is necessary to engage in quality of a picture (probably to borrow operating time at GIS). First of all a good picture, and then all.... With recording on the screw we shall play enough in one month and we shall let alone, and вото we shall look always, very much it would be desirable for promotions in this direction.
3 час. Хитов сегодня: 19
